    Dismiss Notice
Looking for a Drill that i can chase a pipe into a concrete floor?
Discussion in 'Tools and Materials' started by keane14, 10 Feb 2016.
  1. keane14
    keane14
    10 Feb 2016
    14
    Thanks Received:
    Country:
    Just wondered if anyone can help, i need to cut a chase in a concrete floor, does anyone have any suggestions for a drill that i am able to attached a chisel bit too and use as a breaker?
    Many thanks!
  2. Sponsored Links
  3. London Mike 49
    London Mike 49
    26 Nov 2015
    326
    Thanks Received:
    53
    Esseex
    Country:
    The Titan brand in screwfix seem to get good reviews for the price.
    The SDS drills are brilliant for what you want and once you have used one , you will be amazed at the power of these drills.
    One tip though, put a smear of grease on the end of the bit that goes into the chuck otherwise it will be very difficult to remove after you have finished. I made this mistake , and although I got the bit out in the end it was a struggle.
    I now keep a small container of grease in the drill case and put a smear on each time.
    Good luck
    Mike
  4. keane14
    keane14
    10 Feb 2016
    14
    Thanks Received:
    Country:
    Thanks very much for your help Mike!
  5. Burnerman
    Burnerman
    7 Feb 2008
    20,267
    Thanks Received:
    3,948
    Northumberland
    Country:
    It's a good move to cut two grooves in the floor first with an angle grinder / Stihl saw or whatever, and then reach for the SDS breaker.
    John :)
    • Like Like x 1
  6. keane14
    keane14
    10 Feb 2016
    14
    Thanks Received:
    Country:
    Thanks John!
    Basically I have been quoted from a local company to move a pipe,I have a price if they cut the chase and a price if I cut the chase, the difference is about £155. I would have to buy/hire the tools and also find the time to do it, in two minds about what to do!
    Thanks for your help guys
  7. Sponsored Links
  8. Burnerman
    Burnerman
    7 Feb 2008
    20,267
    Thanks Received:
    3,948
    Northumberland
    Country:
    Please be aware, the dust will be indescribable if it's inside.....a Stihl saw can have a water attachment, an angle grinder relies on someone else spreading the water.
    John :)
  9. London Mike 49
    London Mike 49
    26 Nov 2015
    326
    Thanks Received:
    53
    Esseex
    Country:
    The other way to do the chase is to drill a series of holes as close together as you can along the line of the chase then use the chisel to complete the job . At least that way you won't have to buy or hire more tools, all you will have to ensure is that the drill bit is wide enough and you drill the holes deep enough.
    For a wide chase you could drill a series of small holes side by side as above, but as said already, a angle grinder would make it easier.
    Mike
  10. JobAndKnock
    JobAndKnock
    30 Sep 2011
    3,616
    Thanks Received:
    701
    Lancashire
    Country:
    There are wall and floor chasers (based on angle grinders) around which overcome this by proper shrouding - but they require class M industrial vacuum cleaners to stand any chance of clean working. On my current project the sparkies and plumbers are using them. Not cheap, but fast. The chase still has to be cleaned-out with a rotation stop SDS and chisel. In my own house I'd have to opt for hiring. Using a drill for hours on end to the annoyance of neighbours to stitch drill a chase which would still require cleaning-up with a chisel and bolster (or rotation stop SDS and chisel) is not my idea of DIY heaven
  11. keane14
    keane14
    10 Feb 2016
    14
    Thanks Received:
    Country:
    Thanks for the replies, all great information and methods!
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
