I want to replace a pendant light fitting with a flourescent fitting. The present loop-in ceiling rose/junction box is surface mounted and I think it will need replacing so that the flourescent fitting can be fixed up to the ceiling.
Is it ok to use a simple terminal block in lieu of a junction box which can just be pushed up into the cavity above the plasterboard ceiling out of the way? Thanks.
