Loud pipes
18 Sep 2013
Kent
If I turn any cold tap on, a loud yawing sound emits from the area my boiler and kitchen sink are. I can't locate exactly. Some of pipes under the sink vibrate. However, if I turn on any hot water tap, the yawing stops. I have a Worcester Bosch combi-boiler, no tanks.
I do have a dead pipe, which I bled, but to not avail. I have turned the main stopcock down, to no avail. There is also a slight water hammer when closing the hot tap but not the cold.
Thanks in advance of any advice.
Did it start when the combi boiler was installed? How old are the taps, internal wear can set up vibrations.
The boiler was installed 8 yrs ago, the noise only started a couple of days ago. It seems strange that it stops when I turn on the hot tap.
Kitchen tap cartridge. Use a screwdriver as a stethoscope. Noise will be louder at the kitchen tap if I am correct.
Success, the inline valve of the hot tap. The screwdriver method worked a treat. Turned it off and no noise, turn it on and noise. Now replaced for a mere £4 :giggle: . Thank you Mcmoby
