Low level combi flue
not sure yet mate, the landlord is intending to supply his own and he has a penchant for the heatline's from b&q! I'll definitely need to bring the flue terminal up at least a little bit from the otherwise it will be too low. Not sure what sort of flue flexibility u get from the heatline so just wondered what any of you guys recommended.
good luck with the landlord getting his own boiler
as I have said before I would rather remove me own left testicle ( I prefer my right for some reason) with a spoon than do that
way too much hassle
I know what you mean but i'll only be fitting it if it's all above board. It doesn't bother me really, saves me some hassle and i still get paid! I never fit anything that's not fresh out of the box!
I mean if it goes wrong
he calls you
you say call the maker I didnt supply
he calls the maker they say call you
and then he shouts at you
sod that
Yeah but once it's out of warrenty it's his problem not mine. As long as it's fitted correctly then I don't need to worry. I prefer to supply too but It's not a necessity for me. I can see your point though, each to his own eh.
If I fit boilers I don't supply I always put it in writing that I offer no warranty on the parts and if they want me to check it out if there is a fault it will be at my normal call out fees :wink:
sooey said:
Hey you chrisr are you saying us scousers are midgets?
I expect Chris imagines you all have long tools.
Be aware that most boiler flue parts are for internal use only and only flue terminal part is allowed to project a short distance.
Tony
I'm not aware of a manufacturer who will allow their concentric flue to be run surface OUTSIDE.
I think your best bet is something like a Keston, but that is a truly horrible thought.
