low level shower tray trap question
30 Aug 2005
Buckinghamshire
hi there,
I am in the process of sorting out my mums shower cubical and replacing the tiles for a showerwall paneling system ,anyway i done some research yesterday about shower trays just incase i had to remove the tray ,but i found that the waste trap should be easy to access ,but because my mums shower tray is a low level tray i cant see how i can get to the trap if we need to .
So is this alright or does it need to be raised or can you access it somehow and i just cant see how.?
Also i dont know if anybody can make a suggestion but the cubical has a sliding door on it does it matter which side the door goes on,because it was original on the opposite side of the shower head because my mum had complained about water being on the outside of the door after a shower a she wondered becuase the shower water hits the seal of the sliding door and said if we changed it so the door was on the same side of the shower it would happen.
So is the a right way and a wrong way?
Anyway i hope you can understand all this and all the help is appreciated thanks alot
Wow, I think that's possibly two of the longest sentences I've ever had to read. Did nobody teach you about punctuation!?
As for the shower trap, unless you need to take the tray out there is no reason why you should need to get at it. It can be accessed from the top for maintenance by removing the grate. If you want to take the shower tray out, you'll have to unscrew the fitting in the tray from the trap, then pull it out. This might be quite difficult to do if it's been siliconed in. If you don't want to remove the tray, but do want to get to the underside of the trap, you'll have to cut a hole in your ceiling downstairs (assuming this shower is upstairs of course). Having said that, if the tray has been fitted properly, the chances of you managing to lift it up in one piece are fairly slim.
If it's a decent door it doesn't make a difference which way round it goes, the seals will still keep the water in. If it's a cheap nasty thing that's getting a bit old and the seals are knackered, take the opportunity to chuck it in a skip and get a new one.
