Dear All
I have the following problem with my low voltage lighting:
I have a Varilight twin dimmer downstairs and a varilight single slave dimmer at top of my stairs. I have 3 x 50w lV halogen lights downstairs and 3 upstairs. These were working properly until two days ago when non of the lights were coming up. I changed the double dimmer light as I thought it was a problem with that, then some of the lights were not lighting up. I changed the transformer with halolite 50-105w transformer for downstairs and all the 50W lights go through this transformer. All the lights downstirs are working but non of the upstairs ones are coming on, so I changed the upstairs transformers to the same model as I though the transfomer for upstairs had gone and when I switch it on the lights downstairs started to flashing and nothing happened upstirs. I turned the mains off and on and downstirs is working and no lights is coming on upstairs. Im not sure whether I have a major problem with my wiring or its the light switch that is faulty. I am thinking of changing the slave from upstairs but don't want to spend 20 pound or so till im sure. I have wired the master double dimmer wires as Live to Live, neutral to neutral and S to S (with a piece of wire) hope this is a right way for double dimmer master downstirs and single slave upstairs (this is so I can turn the upstirs lights on form both downstirs and upstiars) .
I hope I am making sense as I am not sure about electrics and I think I done everyhtign I could.
Can some one help please.
Much Appreciate it
Much Appreciate it
