Low voltage to shower
7 Feb 2026
The other week my triton shower kicked the bucket. I've replaced the MCB and bought a whole new shower unit, after replacing the MCB and fitting the new shower the voltage was only showing around 50v but used to run at 230v like normal before my old died.
Does anyone have any advice as to what it could possibly be?
Thank you ♥️
Check your wiring for a start, eg terminated correctly? Screwed down on insulation?
Had a sparky out and he reckoned either the MCB or the pump in the shower was the fault, I wanted a new shower anyway and the MCB was only a few quid to swap so it wasn't the end of the world
Exactly which model shower do you have ,and where are you taking the voltage readings ,at the shower or ,
it's isolator ?
Perhaps you should have had a better sparky out... There is no reason the fault could not have been narrowed down. MCB or pump sounds like clueless guesswork to me.
it's isolator ?
triton aspirante 8.5kw electric shower - brushed steel asp08brstl
Taking the readings at the shower mains inside the unit
