Hello all,
I have been reading the forum for quite a while, found a lot of useful information.
I have a problem with low cold water pressure in a top floor flat. It is on the 8th floor of a ex-council estate block. Both hot and cold water are supplied, so I don't have any boilers or tanks at all.
Now, I have a very thin pipe (15 mm) with cold water that above all is metre and a half long and has several bends. It was made to avoid using a broken mains stop valve, so it is connected to the stop valve of the sink and then goes to the shower.
The question is: will the pressure be better if I connect it without this long pipe? I am planning to replace the broken stop valve and connect the shower directly to the dedicated mains. Will this help?
If it will not, I know that I cannot use a shower pump or an electric shower with integrated pump because these do not allow direct connection to the mains. These pumps require a cold water tank. Can I install one in my bathroom? Any ideas how much might this cost? How big it needs to be?
By the way I have already tried a shower pump and it didn't help. So I think it is true that they generally do not work if connected directly to the mains.
Thank you very much!
