    Dismiss Notice
Lump/ridge in my concrete floor
Discussion in 'Building' started by Robpoole, 27 Oct 2009.
  1. Robpoole
    Robpoole
    1 Oct 2009
    63
    Thanks Received:
    Bristol
    Country:
    Hi I have concrete floors in my house and at some point the kitchen has been knocked into a kitchen diner. To that ammends there is a ridge/lump where some of the previous adjoining wall has been (possibly a pantry). It is approximately 4 foot square and is raised about 1.5 inches. There are no water, gas or electrics any where near it and I want to lay laminate flooring over it. The remaining floor slopes away gently and will not be a problem but obviously if I put laminate over the ridge/lump it will look rediculous and the laminate with bend and the joines will show. Can anyone andvise me on the easiest and most effective way to remove this ridge/lump so I can then lay the floor. Any advice on this subject will be greatly appreciated.
  2. Diyisfun
    Diyisfun
    15 Jun 2004
    7,268
    Thanks Received:
    285
    Norwich
    Country:
    You will need to hire a concrete breaker, break away the raised lump, level off & seal. Then lay the floor.
    Its a dusty job, lot of noise also.
    OR
    you could make a step up to it (that wont look nice)
  3. Sponsored Links
  4. mater
    mater
    7 Feb 2008
    188
    Thanks Received:
    7
    Shropshire
    Country:
    you could try a floor planer which is a lot easier and quicker, when taken down to the level required simply put a little self level on and job done
  5. noseall
    noseall
    2 Feb 2006
    43,508
    Thanks Received:
    2,689
    Staffordshire
    Country:
    Are you having a laugh! Ever used a floor planer! Frickin nightmare, noisy, dusty, heavy, horrid, piece of kit!
    Well, the one i used anyhow. :LOL:
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
