Can you give a bit more info, i.e. what type of lighting arrangement you are intending to install, this will help explain how to wire them up.
Also cable size should be either 1.0mmsq twin & earth or 1.5mmsq twin & earth. Do you have LV transformers ?
OK so as they are low voltage do they have individual transformers ? Or is there a multi-way transformer ?
Are you replacing an existing lighting circuit ? If so what do you have in place ?
