O
oompah
I am thinking about installing a macerator in a downstairs cloakroom.I have no other option but are they good or a bad idea.
you say bad why?noseall said:BAD.![]()
Just how noisy are they?Can i put the wc one side of a single skinned 4inch block wall, plumbnoseall said:noisy
unpredictable
always conking out
useless in a power cut
use only as a last resort.
antisocial, especially when people are sleeping.
I have only got enough room under my floor boards tobe able to run 40mm pipe to the soil stack.bernardgreen said:If you are going that far then consider using a small tank that takes several flushes and then under control of a float switch pumps up a "bulk" quantity to the sewers.
Have you had expierence with one thenEdmundo said:If you have to use a marcerator I would only use it on the toilet. Use conventional plumbing for the sinks, shower and bath if possible. The nose it makes is short and predictable with a loo but long and noisy if you're having a shower etc...
Thanks for the info I think I might go for the sanibest which according to saniflo website should cope with i want to do.I will not have no vertical pump but i can get under my floor boards.Did you have to inform building control about installing xtra loo.Edmundo said:I installed one in an upstairs loo. I needed the marcerator as the loo is in the middle of the house so it would be very hard to plumb the soil pipe in (no verticle pumping). I have a sanitop which the sink plugs in to aswell.
The sanitop works fine, it's quite noisy (abit like a full blender going off) but thats to be expected. It pumps for about 8 seconds after a flush, not too bad, we just don't flush it at night. Sometimes poo's take a couple of flushes!!!
The problem with the sink is that when you are running the tap the sanitop pumps for about 1 second every 6-10seconds or so which is an annoying sound and you risk waking people up at night. In my case when I did the plumbing it wouldn't have been that hard to use traditional pipe work for the sink.
My saniflo comes with an onsite 2 year gaurantee and so far has been fine just be careful what goes down the loo, I'm not looking forward to the day that it needs to be unblocked! Hopefully will have moved by then!
