Magnetically enhanced back-draft damper
15 Feb 2007
I once read a suggestion that a magnet might be used to fully close back-draft dampers. The general response was that magnets would be too strong.
You might like to know that have now used a magnet successfully and it works well. There is a satisfying 'knock' as the damper is pulled right in.
The trick is to have the magnet at just the right distance from a small piece of steel fixed to the damper. If the distance is too far then the magnet won't overcome 'the pull-in distance'. If the magnet is too close then the fan won't blow the damper open.
Whilst frequenting the bathroom last night I was wondering what I could use to stop the wind from howling through the bathroom extractor and making the bathroom really cold.
I'll look forwards to seeing you on Dragons Den
Thanks for your reply Chirpychirpy. No chance of going on Dragons Den! Magnetically Enhancing a back-draft damper is only for people willing to make something to suit their own system, I think.
Simple cowl tends to prevent backdraft in many cases .
