It's common to use junction boxes on a lighting rewire if narrow switch drop conduits get re-used, and the light fittings don't have space to accomodate more than one or two cables.
surely it depends what there used for, are they used just to terminate at the lights, some fittings are tricky to get multiple wires in and makes sense to use them
Connect the cables into the terminals at the light fitting (or any other device).What do you mean by terminate?.
I've got some which have no terminals at all - the only connection to the lights is via an integral plug & socket arrangement - the plugs are more than just tricky to get multiple wires in - they are not designed for it and it is impossible to do.surely it depends what there used for, are they used just to terminate at the lights, some fittings are tricky to get multiple wires in and makes sense to use them
Those things are pretty useful. Scolmore downlights come with them ready to go (obviously, it's the same company) But their downlights have a 7 year warranty, means if they fail within that time, the end user is able to swap out the fitting without having to get anyone in (and maintain their warranty)This is a junction box:
There might be very good reasons for using them (but not wired as per the photo)
Sounds like you want one of the following:The ones I have have an obscure 4-pole connector (EM lights, so there's a L & SL). I say obscure as I seem to have one fewer plugs than I have gear trays, and I'm b*Y"(%&#@d if I can find one anywhere. I can find similar ones, but not with the right combination of obfuscated-is-it-male-or-is-it-female shrouded pins and prongs and receptacles.
