What is the best way to make a sound compression fitting joint without a leak/drip? I made 5 this weekend in my house and 2 were leaking, although I believe I may know possibly why? I have mains pressure all over so maybe this made it worse?
The pipe should go into the fitting up to the stop so fully in. And the olive then pushed down to the fitting and the nut tightened with fingers and then grips. Not overtightened though or the olive may be crushed. This is correct isn't it?
Is there any good tip to make sure it will be sound? Compound any good? ptfe/locktite on the olive/in the fitting or on the pipe end?
I believe 1 of mine was spraying possibly as the pipe wasn't fully in ? And the other a dribble as the pipe was not cut great/squarely, so I changed and got a new pipe slice with new sharp wheel and the others were all good. I am just trying to work out why this happened so in the future when I need to ake a join I will be confident.
Sorry if this is basic and sounds daft but I would just like to know where I went wrong if i may?
