Making a subfloor even
23 Jan 2023
Hi all,
My floorboards are 8mm out of level. Can this be fixed screwing plywood to the floorboards.
I will be laying engineered wood flooring with a 5mm underlay. Hopefully this will give me some grace.
If so what size plywood should I use?
Many thanks
Doesn’t need to be level flat would be ok. but putting plywood down Won’t make it level On its own. You will need to use smoothing compounds As well
What size plywood would you recommend?
