Makita 8444 18V MXT Drill
18 Nov 2007
I seem to have an addiction to new tools at the moment! :LOL:
Well I bought a Makita 8390 18V the other day:
http://www.screwfix.com/prods/77831/Power-Tools/Cordless-Drills/Makita-8390-DWPE3-Combi-Drill-18V
Been using it a while now and seems to be up to the job, just one thing that bothers me is the slower higher gear. I would like it to be a bit more especially after trying to drill into some brick the other day. Also cutting holes with it could do with a bit more torque...
Anyway I digress... I was wondering what could be a good upgrade to the drill I already have and came across this gem:
Makita 8444 18V
http://www.screwfix.com/prods/75772/Power-Tools/Cordless-Drills/Makita-8444-DZ-MXT-Combi-Drill-18V
Now this seems to tick all my relevant boxes, 3rd gear with higher rpm and more torque to boot! 80nm in fact! Brilliant. Now this can be had off the bay for a mere £70 for the bare drill. And I could sell my bare drill for about £30-40 and make up some of the difference. So for say £30-40 I could get a nice upgrade! I'm 99% sure my PA18V batts will fit, the only worry is battery life might be reduced being it only 1.3Ah NiCds...
What you reckon is the drill worth upgrading for? Anyone got one?
Cheers
you do realise the greatest torque is in low gear the higher the gear the lower the torque
could make either drill provide several thousand nm of torque with mechanical gearing but very very slow revs
Yeah I do realise that it just seemed like a worthwhile upgrade, with the higher 3rd gear and more low down torque, would be useful for driving too even though an Impact drill will be my next purchase. Also not sure what the significance of the MXT is?
Well I bought one! :cool:
Man this drill is one serious bit of kit! The extra torque is very nice. I just drilled out a 36mm hole in some 2" timber with ease, and still had quite a bit of juice left in my 1.3Ah batts. my other 8390 drill struggled with it.
Extremely happy with this purchase, however it is a little bit heavier at 2.7KG, but for heavy drilling this is perfect.
I might just keep the other drill as a backup now.
Also the MXT means Makita Xtra Torque, it sure does that!
http://www.makitauk.com/index.php?page=75
Yeah I'm getting some 3.0Ah batts these 1.3 ones are way too wimpy. Also is the chuck meant to have about 5mm slack in the spindle lock position? Mine turns like 5mm clockwise and anticlockwise just wondering if that is normal? My other Makita has no slack whatsoever. When you are drilling and you stop the chuck spins like 5 mm and makes a little clonk noise, i just feel over time it might knacker the drill...
Hi, just a wee note about the batteries. make sure you get genuine Makita batteries and not the copy ones on ebay as i've bought them before and the clips eventually stop working and your battery will fall out :mad:
Mine is exactly the same and has been working beautifully for over 2 years so I wouldn't worry about it. Probably a feature of the electric brake.
OK great thought it was just mine!
