Hi everyone, can someone please explain how this works. Please see picture. I suspect it’s some sort of manual air release? If so, can it push air around the whole heating system if the air is not let out?
I turned it anti clockwise for about 2 seconds and had a strong hiss (of air, I suppose) and closed it immediately.
Could this air be causing air in some radiators? I have 1 small radiator near it on first floor, which makes noise (popping usually) and usually has air in it
1- should I open this bit at the tip of that pipe to let the air out , just like bleeding any radiator? Should this be bled like the other radiators ?
2- could this air be going round the whole heating system if I don’t let it out?
3- could it be why this small radiator near it makes these popping noises especially when heating first come on? I initially thought might be just the radiator expanding with heat on but makes noises intermittently when already hot
Thank you
Thank you
