It depends on the wall behind the tiles. if it is a plasterboard (drywall); then I would advice you remove the plaster wall and install a brand new one. It does not cost much.
Otherwise if it is masonry wall; then you will have to use force to remove the tiles; and then remove the adhesive with a knife.
