Hi all,
I know this strictly isn't a plumbing question, per se, so apologies in advance.
I have just recently built a new workshop in my garden, just for hobbyist woodworking and messing around mainly. And in here I want to run air line up the walls and over the roof to keep from having hoses dragging the floor like they used to in my old garage shop (which is incredibly annoying and dangerous).
So, to my question. I already have a few lengths of 15mm copper pipe and a load of brass compression fittings from another project but can't find any information on whether this is a good option (max pressure wise) to use for my goal. Compressor is limited to maximum 10 bar but the regulator is always set to 8 bar.
I would only need to buy 1/2" BSP end elbows if it was possible.
I looked at JG Speedfit airline pipe but it would cost about £200 to do it when I already have stuff there.
Google suggests copper is ok for airlines (non corrosive etc) but each application seems to be solder ring joints an no one mentions compression fittings (which would make adapting the system in future easier (if I want to run another branch across to the back of the shop for example).
Again, apologies it's not strictly plumbing related but hoped someone might know the answer to the title question... "how much pressure can a brass compression fitting survive under?"
Thanks all in advance.
