MCBs
19 Feb 2008
Nottingham
Hi, I have recently upgraded my shower circuit, I know that I need to upgrade the rating of the MCB to 40A, which I have bought today. I have a wylex consumer unit with wylex MCBs. The 40A wylex mcb that I bought today is slightly different in size but it does fit. The existing mcbs have a blue trip switch and the new one has a black trip switch. My question is, is this the correct mcb even though it is the same make, or are there different sizes or types avaible? Also is it possible to mix different makes of mcbs? just a question for future reference!
kwil69
Hold on there a minute.
When you say that you have "upgraded your shower circuit", what did you do?
Have you installed a new thicker cable or have you just put in a more powerful shower to replace the old one?
and are these Wylex MCBs the sort that plug in?
A photo of your CU and the surrounding cables would be nice.
Brace yourself for bad news.
Sorry, i have upgraded the wiring as per regs, including sup bonding. The MCB is the one that fits on the buz bar of the consumer unit. [/b
photo of CU and MCB please
there are various ranges
http://www.diynot.com/forums/viewtopic.php?t=99672[/QUOTE]
I dont currently have a digital cam to take pictures. Its a Wylex Consumer Unit fitted about 8 years ago, its a split load board with RCD. The new cable that I heve installed is 10mm2, for a shower of 9KW. I have tested continuity, resistance etc etc. I only want to know if there are different types of type B breakers?
It will have the range on both the breakers by the current rating.
And on the main switch or cover somewhere
Can you see what is on both old and new mcb and post it
Not many wylex ever used coloured switches
The Ns range had various coloured dolly switches depending on size
Blue would have been only for 16 a though ,now most wylex replacements now have black switches AFAIK
Regarding different makes and wylex ranges, Sometimes they look similar but the bus bar connection can be spaced different
I know the ones you mean, but just cant think of the range
The Ns range had coloured dolly switches ,but some wylex replacements now have black switches AFAIK
Please give me a few minutes and I will have a look, please hang on a min[/b
Right then here we go -
The existing mcbs have the following markings on them: CPN MC132B, B32, 230V-EN60898.
The new MCB is the following: Wylex 40A SP Type B MCB 6kA, 230V AC, 6kA, BS EN 60898
all that is standard stuff for most mcb
None of that seems to be the range though
Cant recall a CPN though so dont know what that is,
Sure that was a wylex, not something else
Was there anything on the board cover,
If not see if you can see it on the wylex website
It is the range that determines what you need I am afraid
CPN is a Cudis not a Wylex breaker. See here
http://www.cudis.co.uk/Cudis-CPN-MCBs.htm
Maybe thats why you've got a blue switch.
Magic! sorted then! its just that I thought as the cu is wylex, naturally thought that the mcbs would be!
Anyway, it fits on the buz bar with the rest of the CPN breakers, but is it ok to mix makes? there is only a slight difference with the Wylex breaker, and that its slightly taller, but is does fit. If I cant use the wylex one I will change it for the CPN one. [/b
No problem, thanks everyone :)
Always nice to keep the same , if poss
Someone in future might see it and think it Is a bodge ,
I personally would change it as you may not get another oppurtunity if the range becomes obsolete
If I see it I would wonder what was going on and take a look,
Anyone buying the house may think similar and cause them to probe deeper to see what else may be lurking.
