Hi! I´m new to the forum so I hope I´m posting in the right place.
I plan to build a panel wall (a sliding hanging door) using those wheels and rails http://www.ducasseindustrial.com/images/productos/DN 80 SR/dn80sr_manual.pdf
The door measures 150x220 cm and I will use 25mm MDF. For this specs the door weight is about 50Kg.
8 screws will be supporting "hanging" the 50Kg of the door. Would that be enough or I should think some other solution?
Thanks!
Thanks!
