D
Doctor Drivel
Because I'm planning to have a loft conversion, I thought it would be a good time to consider having a dry loft and installing a Megaflo system - the Heatrae Sadia Megaflo to be installed in place of the the hot water cylinder in the airing cupboard on the 1st floor. I currently have 1 bath/shower room and 1 shower room with another shower to be installed in the loft when it gets done.
The plumber came out and tested the flow rate and said that at 12 ltr/p min the flow rate was not enough for a Megaflo
Fit an accumulator, they work. Reliance do a good one. It is the size of an unvented cylinder. Then fit a high flow combi like the Ethos 54C @ 22 litres/min. The Ethos is a quality product and delivers. You don't want two large water cylinders in the house.
http://www.heatweb.com/products/accumulators/accumulators.html
http://www.heatweb.com/pdf/RWC/Accumulators.pdf
http://www.rwc.co.uk/Product.aspx?page=CAT6
No 3. Replaceable Membrane Potable
http://www.ethosboilers.co.uk/products_54c.php
Do not bother with a pump.
The best way is an accumulator. It is passive and requires no pumps valves or anything. Just one 22mm pipe to the cold water mains pipe and a double check valve at the stop cock. "" from accumulator to combi inlet. The accumulators does not and cold lines.
No needed for thermostatic shower mixers, just a combi mixer with an integral equalisation valve.
