merlin 65/95 oil boiler
30 Jan 2013
Suffolk
Hello all,
I have a Merlin oil boiler to service next week and have desperately searched the web for a service manual as I would like to arrive prepared.
Can anyone out there give me the commissioning data. i.e. nozzle size, pump pressure?
Please........
This will all depend on model, burner type etc. most have a sterling burner and are generally set up with the pump pressure at 100psi, but obviously there will be some differences. With any luck there will be a record card from a previous engineers visit.
I look after quite a few of these although mainly smaller output ones (40-60k ish btu) and have found them to be easy to work on and very little problem over the years. I will have a look in the workshop tomorrow to see if I have any more info
Simply replace existing nozzle like for like and measure pressure.
If it is burning ok as I am sure it will be you won't need to alter anything.
There might even be the correct nozzle and pressure settings on the boiler somewhere.
