- Joined
- 12 Feb 2007
- Messages
- 27
- Reaction score
- 0
- Country
Hi everyone,
First off, please don't shout at me, as all I have done is replace a switch and I believe I have done everything correctly!
In my kitchen I have some downlighters on one circuit, and a main light on another, both originally wired into a metal 2 gang dimmer switch. At times, when switching the lights, you could get a slight buzzing feeling off the casing, and sometimes a slight nip when switching the light so I presumed it hadn't been earthed correctly. One of the dimmers went, and I don't like dimmer switches anyway, so I have replaced with a metal 2 gang 2 way toggle switch.
I've wired both switch cables as follows: Red to common, black to L1, and earth to the earth terminal on the pattress. I've run an earthing cable from the terminal on the switch plate to the earth terminal on the pattress. Both switch cables are twin and earth and are both also earthed onto the pattress.
However, now I've put the lighting circuit fuse back in, there is still a slight buzzing feeling if you touch the casing, and just occasionally, you get a slight nip when switching the lights on or off. The lights work fine however!!!
Is there anything I'm missing?
Thanks in advance for your help.
