Hi, Had a horrendous time today putting up a metal ceiling light and now I'm concerned about the safety of it.
I have had to use a choc block to extend the neutral as couldn't get enough slack to fix it. The neutral wire was a few mm too short so in my frustration and several attempts at connecting I managed to break a metal strip which went from the earth hole of the choc block (which was already fixed in the light fitting) to the metal casing. This strip was prefitted to the light to ensure it was earthed once I connected the earth wire from the ceiling.
So, 3 questions
1) Is my extending of the neutral wire using a choc bloc safe enough?
2) How do I reattach the metal earth strip (which acts as the earth wire) back to the metal casing?
3) If there is no way to attach the earth wire/strip back on to the casing, is there another option??
The new light is a really expensive one and I can't afford a replacement.
Thanks in advance,
Jeanette
So, 3 questions
Thanks in advance,
Jeanette
