Hello,
I help out a local amateur theatre and they've been doing some electrical work over the last few days.
One of the things they've done is installed a few new sockets, and the way they've done this is installed inside a partition wall some metal (20mm) conduit which connects at one end to a metal besa box, which has some T&E entering it via a gland (the lid of the box is accessible for inspection and maintenance etc and the T&E runs vertically down so is in a safe zone), and at the other end connects to a plastic dry lining box with a 13A double socket mounted in. The conduit also has a T which goes off and emerges on the surface across a perpendicular wall, and goes to a surface mount 13A double socket.
My concern is whether the conduit where it meets the dry lining box needs to be connected to the CPC in some way - with a metal back box it would obviously pick up the CPC from that, but in this case it won't. The conduit as a whole should pick up the CPC from the surface mount socket, but my understanding is this doesn't comply alone - to comply with regs do they need to put e.g. a suitable ring between the conduit bush and the conduit and attach a CPC to it?
