That does sound a bit rough, and offensive in the way that misuse of a tool is.We tend to use a pair of closed pliers inside the end to get rid of the sharp edges.
A pipe de-burrer may work better such as this: http://uk.rs-online.com/web/p/deburring-tools/2063479/[/QUOTE]
Not that one
"suitable for use on copper, aluminium or brass"
But that's not the point.A pipe reamer is what you want but pliers or side cutters do the job just fine.
Because it's the misuse of a tool, and therefore offensive.
... Are you also a "spark" that thinks the standard way to use a bending machine is to pull the lever upwards?
You get up on a small scaffolding tower, of course.Not sure how how you bend a 3.75m length of conduit it the middle without going upwards![]()
We tend to use a pair of closed pliers inside the end to get rid of the sharp edges.Don't forget to file off the sharp burr from the conduit ends to avoid cutting into the cable.
Thats because you've never been properly trained into how to install steel conduit. Are you also a "spark" that thinks the STANDARD way to use a bending machine is to pull the lever upwards?
