Why should they? There is no requirement to use metal.Will the DNO now fit metal isolator switch enclosures rather than plastic. I expect not!
Indeed - and, in any event, I'm not sure that a standalone isolator switch necessarily qualifies as a "consumer unit or similar switchgear assembly", does it?Why should they? There is no requirement to use metal.Will the DNO now fit metal isolator switch enclosures rather than plastic. I expect not!
Apart from being a bit of a grammatical mess, what on earth does the second bit of that mean? It seems to almost imply that non-combustible CUs were not permitted prior to the appearance of this new regulation!The implementation date for this regulation is 1st January 2016, but does not preclude compliance with the regulation prior to that date.
It means you can comply earlier if you want.
I know that's what it says, but why is it saying it? Wasn't it equally permissible to fit a non-combustible CU in 2012 or 2007, or .... ? What has the new regulation (or the period between 5th Jan 2015 and 1st Jan 2016) got to do with this?It means you may fit (and comply with the new regulation) before 2016.
I don't really know what they intend. If you (and your criteria) are correct, then where does one stop - do you include standalone RCDs, shower isolators, cooker control units, switch fuses ..... ??I would have thought that an isolator was a switchgear assembly. ... And it has plenty of current flowing through it to create plenty of heat.standalone isolator switch necessarily qualifies as a "consumer unit or similar switchgear assembly
But some 'electricians' tell people that their rewirable fuse box is illegal and must be replaced.I know that's what it says, but why is it saying it?
OK, it means you can claim compliance with the Amendment before it comes into force.It means you can comply earlier if you want.I know that's what it says, but why is it saying it? Wasn't it equally permissible to fit a non-combustible CU in 2012 or 2007, or .... ? What has the new regulation (or the period between 5th Jan 2015 and 1st Jan 2016) got to do with this?It means you may fit (and comply with the new regulation) before 2016.
Kind Regards, John
Not according to the definition in 61439 it isn't.I would have thought that an isolator was a switchgear assembly.
I doubt that many would disagree with that - since it's "similar to a CU". ... but what about shower/cooker switches/isolators etc?Well certainly shower rcd/MCB units.
I must say that I wouldn't read it as particularly 'encouraging' me to do that. It is merely telling me that I am 'allowed' to do something during this year which I have, in fact, been allowed to do for decades!They want to encourage fitment ASAP rather than wait a year.
