    Dismiss Notice
Metal Shed Insulation
Discussion in 'Building' started by Antony11, 8 Aug 2020.
  1. Antony11
    Antony11
    10 Jul 2020
    22
    Thanks Received:
    Country:
    Hello,
    I am building a shed in my garden. The stud walls are going to be made from treated cls, 16 inch centres and will be cladded with metal box profile cladding on 3 of the 4 walls.
    On the front wall I am going to be using wooden cladding as it's the only visible wall and the only wall that needs to look shed like. The other 3 metal/ stud walls are surrounded by fences. The inside is going to be plylined.
    So I have bought the insulation today which is rockwool flexi as its cheaper than kingspan or that type of PIR insulation and it says its suitable for metal stud walls.
    The wall thickness is 63mm and the insulation I bought is 50mm.
    So my main questions are:
    Do I butt the isulation right up against the metal cladding or leave a slight gap for air flow?
    Do I need ventilation going into the stud walls themselves?... I am making ventlilation going into the shed cavity itself but not sure about whether the stud walls need there own ventilation system? If so any ideas on how to do this?
    ... Pretty much my main concern is I don't want condensation building up on the metal cladding behind the plylining and then one day find out its all damp and moldy.
    So any advice regarding this situtation is appreciated.
    Many Thanks,
    Antony
  2. Sponsored Links
  3. bennymultifinish
    bennymultifinish
    21 Apr 2020
    1,651
    Thanks Received:
    266
    Country:
    not the way i’d do it. i’m going to be building a whopper in the garden shortly.
    like yours , 2 of my external walls wont be visible and are on the boundary, but the most exposed to wind and rain. i’m building it from 4x2 treated .panelling the exterior with osb covered in roofing membrane then my profiles will be screwed to that.
  4. ^woody^
    ^woody^
    3 Sep 2006
    29,331
    Thanks Received:
    3,788
    West Mids
    Country:
    Any air gap on metal sheet will produce condensation. Quilt insulation is air permeable.
    You'll need to construct a sealed insulated frame, form a minimum 25mm fully ventilated and drained air cavity, and then fix the metal sheet.
Loading...
Share This Page
