Thanks...yes, appreciate that.It’s holding down the wall plate (timber at the top). Could be repositioned to nearby if you can access to nail/screw down the top of it
Thanks....It would have to move quite a lot...about 10mm..the strap is a long way off true...Move the stud a bit.
I don't think I can move it to the right, access at top is too difficult but I will double check.
Is it really necessary, given the weight of the roof means
Hello...just checked top access...can get two *maybe* at a push three screws in.Can’t you just move it to the right of the stud in your pic?
Edit - didn’t read your reply fully. I’d Deffo try to move it. Try and skew a couple of screws in at the top
Or fix the stud on top of it, packing it out below as needed and fixing through it into the block?
