Just had an interesting phone call.
A customer in the middle of self build has had a temporary supply for about 4 years, that might seem a lot but covid changed things a lot for them. We installed a GRP enclosure on a couple of wooden fenceposts, this is somewhat bigger than a regular meter box, from memory I'll say 1m high x 600wide, and the original expectation was a standard meter box would be mounted on the other side of the posts.
The enclosure contains an isolator, Henley block, 60A fused switch feeding mobile home, CU for site work including 5KVA 110 transformer & second CU (No main switch) with double pole MCB's. We were on site installing when service was provided and they fitted cut-out and meter in the enclosure and even provided tails into our isolator, to add insult to injury they took the meterbox with them.
The visit today was to fit smart meter, customer has been given notice remove unauthorised items from the enclosure...
Customer is intending to look at CCTV as he has saved great swathes of salient points as a history of the build.
