Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Do you have to install 25mm tails if upgrading a CU? Can the existing 16mm be used? The main fuse is 60A so surely 16mm is sufficient. Its just i am changing one tomorrow and are planning on using it for my NIC assessment and want it to be right in there their eyes
16mm² is fine for 60A, but are you positive that there is a 60A fuse in the carrier? Th label is not always correct so it's usually a good idea to fit 25mm² tails anyway.
