Does anyone think it is about time to do away for good the imperial system, with its non-uniform and unscientific measurements? It is also a mis-mash of different country's measurements - some from France, Italy, Germany, England, biblical.
notb665 said:with its non-uniform and unscientific measurements?
1983 October 21 — The seventeenth CGPM defines the length to be distance travelled by light in vacuum during a time interval of 1/299 792 458 of a second
1960 October 20 — The eleventh CGPM defines the length to be equal to 1,650,763.73 wavelengths in vacuum of the radiation corresponding to the transition between the 2p10 and 5d5 quantum levels of the krypton-86 atom.
The number of litres volume of fuel, where a litre is defined as a volume equal to that occupied by 1 kg of pure water at the temperature of its maximum density (3.98 °C) under a pressure of 1 atm, where 1 kg is the mass which would be accelerated at precisely 2×10−7 m/s² if subjected to the per metre force between two straight parallel conductors of infinite length, of negligible circular cross section, placed 1 metre apart in vacuum, through which flow a constant current of exactly 6.241 509 629 152 65×1018 elementary charges per second, required to allow the vehicle to be propelled under its own power for a distance of 100km, equal to 16,507,637,300,000 wavelengths in vacuum of the radiation corresponding to the transition between the 2p10 and 5d5 quantum levels of the krypton-86 atom.
Not really, could you explain it from a quantum angle?AdamW said:So, do you want to measure your fuel economy in mpg, or would you rather:
The number of litres volume of fuel, where a litre is defined as a volume equal to that occupied by 1 kg of pure water at the temperature of its maximum density (3.98 °C) under a pressure of 1 atm, where 1 kg is the mass which would be accelerated at precisely 2×10−7 m/s² if subjected to the per metre force between two straight parallel conductors of infinite length, of negligible circular cross section, placed 1 metre apart in vacuum, through which flow a constant current of exactly 6.241 509 629 152 65×1018 elementary charges per second, required to allow the vehicle to be propelled under its own power for a distance of 100km, equal to 16,507,637,300,000 wavelengths in vacuum of the radiation corresponding to the transition between the 2p10 and 5d5 quantum levels of the krypton-86 atom.![]()
Is that scientific enough for you?![]()
So you can really 'act' your shoe-seizeAdamW said:Shoe sizes? Why the HELL am I a size 46?!
WoodYouLike said:Why are there 12 inches in a foot? Or just over 3 feet in a yard?D
petewood said:WoodYouLike said:Why are there 12 inches in a foot? Or just over 3 feet in a yard?D
Hope you don't sell flooring by the yard if you think a yard is over 3 feet!![]()
WoodYouLike said:more than 3 feet to a yard (3.15 feet ?)
WoodYouLike said:Never to old to learn![]()
