just had a two storey extention built.
I have three new rads i would like to add on.
the house has a convensional heating system (header tank etc.) linked to a potterton boiler and the rads run off micro bore (10mm).
rad No. 1 is just a replacement on a different wall, so think i can just tap of orignal pipe work?
Rad No.2 and 3 are in the extra rooms, so ill have to track back to the flow return source?
just a couple of questions i would like to put out... I am struggling to find the manifold, are there any methods of locating it? and rcommended connectors?
In the the cylinder cupboard the flow and return pipes are visable but dissapear under the floor. if i cannot find the manifold where would be the best place to tap into the pipe work and are there any rcommended connetors ? (i was going to do it in plastic)
is there a limit of how far to run the micro bore from the manifold?
hope this is understandable.
would really appreciate any help, cheers
