Microbore radiators with injector tubes
21 Mar 2006
Hampshire
Do you know of any brands suitable for twin entry on ONE bottom end
only (ie twin lock valve with injector tube/worm) as i don,t want to replace
the pipe work to fit bottom opposite end rads.
Many thanks P.
I think I have badly worded what I'm after,that is I'm after a brand of
radiator that will take the valve AND injector tube (a rad with a sump
type base rather than 'H' type rad).All the rads I've seen so far only allow the tube to go in 1-2 inchs because of the rad construction.
Thanks P.
Sorry, I thought you meant the twin-entry valves. I think pretty much all rads have those spherical lumps welded on which I don't suppose you could feed a tube through (have you tried with the flexible insert?). Personally I wouldn't bother with the twin-entries. You won't be able to have TRVs with those.
guess your right was just trying to avoid having to run a'run round pipe'
along the botom of the rad :rolleyes:
Cheers P.
You can as an alternative extend the flow pipe up to the top tapping on the rad, where you can fit a TRV.
