Hello experts
I need some help
I have a diverter valve (4073A) which is doing something unexpected, (and I'm too lazy to look through all the previous posts).
If we start off with no power,
then turn on the power
and then select CH with the thermostat calling for heat,
the motor will open the valve and the lever will move across and start the pump and boiler.
If the DHW is selected,
and the cylinder stat calls for heat the valve will go to its mid position.
DHW stops calling, and the valve goes back to heating.
Now then, if the CH is turned off at the programmer or the room stat stops calling for heat, the valve stays at the heating position, though the pump and boiler stops.
The valve will return to its rest position only if the mains to the heating system is removed.
I have replaced the valve and the symptoms persist. There is probably a wiring fault, but I have not been able to work it out.
Any ideas?
I need some help
Any ideas?
