Hi can someone help please? The two red lights "Check drain" "Check Inlet" keep coming on after about 2 weeks worth of washing. This is the leak detection wit a sort of float switch in a small sump in the bottom of the washer. When I strip it down there is water in this sump but I can't see where it is coming from. Is this a regular thing? I was going to change the door seal but they are £90 so would rather not spend that if I don't need to.
Cheers,
Stu.
Cheers,
Stu.
