Miele W562 washing machine purchased in 2009. (4.5 years old?). Used on average one wash per day.
Out of warranty.
When turned on the sump pump comes on and runs continuously. After a minute or so the soak/pre-wash light starts flashing, motor keeps running continuously.
The machine does actually drain water completely.
I've checked the following:
Sump pump drains water completely
Float ball in sump moves freely and creates a seal when water is all drained.
No blockage in "pressure chamber" or hose to pressure switch
Pressure switch hose seems in good condition
Based on this I fear that the fault lies either with the pressure switch (mounted on the main PCB) or the PCB itself. This is around the €400 mark according to miele parts department. (in addtition to callout fee)
Before I decided whether to dump machine or call out Miele, can anyone tell me:
Is there anything I'm missing that could cause this?
Is the machine looking for atmospheric pressure at the switch to indicate draining finished? If that's the case, can I confirm the diagnosis by disconnecting one end of the pressure switch hose?
Out of warranty.
