8 years is no age for a Miele washer. I have seen many 10 - 15 year old machines that ran like quality Swiss watches.
Wiring can get damaged & connector plugs can loosen, it does happen. Take the front off & see what you find. Did you try a pump cycle with the filter out to see if the impellor actually rotates?
Under the lid you should find a wiring diagram (all Miele machines are supplied with one). If you don't find any obvious fault on inspection use the wiring diagram to identify the pump wiring back to the pcb & check the cables for continuity. If you want to check for 230v at the pump on an empty cycle (with the front off) you will have to activate the door switch with a screwdriver. Be careful
I don't think I have ever ran into a problem with a pump triac/relay on any Miele washer.
