if you've got a water meter then it's a good idea to get a mini expansion vessel on the cold mains as without it you're more likely to get a leak on the cold in/hot water circuit due to water hammer. if you didn't have a water meter you probably wouldn't need one.
you heard you need a mini exp. vessel?
wos someone talking about you and your boiler in another room
or something?
the exp. vessel takes the expanded central heating water into a vessel located at the back of your boiler.
hazard a guess that the pressure gauge on your boiler is going up to 3 bar,
prv lifting and you lose pressure, so you have to top up boiler pressure.
So who and why has 'someone' said you need one?
You've already got one in your boiler- they will know this.
So why are they saying you need another?
P.S.
Save your money -find a good local RGI
That very same job
proberbly you need one for the dhw supply due to having a water meter its stated in the MIs.this is so WB cover themselves under warrentry when somthing goes on the boiler.
