Mira 415 Leaking
23 Jan 2007
Bradford
I have used search, and hopefully I'm halfway to an answer :)
My parents have a mira 415, no idea of its age. They popped off to Spain for winter (benefits of being retired) and their new condenser boiler broke down (pipe outside frozen), which allowed the house to cool down, and freeze, which led, in turn to about 10 burst pipes and a lot of mess.
As I'm not a plumber, and finances are very, very tight, I've just finished getting the house dry, and the heating back on. Now the only issue if the shower. (and re-decorating :( )
It is a Mira 415, and seems to be constantly on, fairly low pressure coming out of the head, which does increase as I turn the dial to actually turn it on. I'm guessing I need a seal kit, is it a simple thing to change the seals? Does it all happen via the tap on the wall (and if so how do I disassemble) or is there another part, possibly underneath the bath (tiled bath panel :() that i need to do something to? I haven't bothered testing the temp of the water through the head, never crossed my mind until now that it might matter.
Or maybe I need the cartridge?
thanks for any help.
no answers, but follow up for anyone else with the same issue.
I replaced the cartridge, which stopped the permanently running problem, and then showed a new one, the shower now leaks from the "tap" when on. I figure this is probably the gasket, which looks perfext but at nearly 20 years old is probably worse for wear. Being a tight northerner I plan on using silicone to refit everything, as £15 for a big washer seems obscene to me.
Following advice on this and other threads for a leaking (early MK1) Mira 415 shower I have just replaced the (grey) cartridge. The shower is now working fine again with no leaks - thanks.
However, the shower was so old and probably hadn't been dismantled from new and I unfortunately damaged the now brittle central cap which covers the screws for the removal of the control knob. Searching I have found the Mira part is "Mira 415 control knob cover cap (107.27)" shown here
http://showerspares.com/search/mira_415_control_knob_cover_cap_107.27/
but the part is now listed as "Obsolete" and neither Mira nor any of the on-line suppliers I have found has one in stock.
Can anyone suggest another source (e.g. second-hand spares supplier) or if anyone is replacing an old Mira 415 and is willing to send on the plastic part please get in touch.
This is what you are missing. I did exactly the same and didn't notice the collar and rubber washer, shown here on the old cartridge. Once replaced working perfectly.
Available on Ebay UK
