Hi all I have been living in my new home for around a year, during the summer the shower is fine, keeps warm/hot for as long as i need, i realise partly due to the fact it is naturally warmer too.... When it comes to winter the shower goes cold after around 3-4 minutes. at this point I have to then keep increasing the heat until eventually im at the max possible and even that goes cold a couple of minutes later.
the shower is a Mira Combiforce 415 EV and the boiler as described is a Vaillant Ecotec 824... I use the shower head on the economy setting so it should be the lowest flow possible.
the boiler is in the loft if that helps. also another thing i noticed is the bathroom tap takes a while to get hot and the flow seems to be very poor compared to the tap in the kitchen which can belt out water with some force.
I also noticed the boiler has a hot water and seperate radiator heat dial on the front. would increasing these help? or would that just make it get hotter and run out just as quick?
I'm pretty much a plumber novice so my knowledge is limited.
thanks in advance....
