hi all
couple of newbie questions i hope i can get some help with:
hoping to install a mains fed electric shower in my bathroom, first floor, in a normal 3-bed semi type house,
if i 't' off the rising mains at attic floor level, before cistern stopcock, and across coupla joists & drop down to the shower, will i lose much pressure as compared to coming off the mains at 1st floor level , across bathroom and up to the shower ???(which involves a lot more destruction and working inside a tiny cupboard, alice in wonderland comes to mind
eat me
2
checked mains pressure in attic, just before cistern stopcock and was getting 1.8bar and 3.5-4l minute flow(from a 15mm plastic pipe), dropping to 0bar when kitchen tap was open full. Does this seem like enough of a flow to service one of these type of showers
3
the mains pressure seems to be in the requirements of the manufacturer (1.0bar to run normally, 0.7bar min) but i noticed it needs a static head of 0.2 bar to keep the inlet solenoid closed. Will the showerhead dribble water when the kitchen tap is in use, or the dishwasher or washing machine are drawing from the mains feed, for that matter -when the shower is not in use.
if anyone has any experience in this i would love to hear.
I will presume the shower will not run when these are in use due to the pressure drop
The mains feed up through the house is 1/2" black poly
the rest of water in house is gravity fed system hw-cylinder etc
any help on any of the above greatly accepted
