Hi guys
Thanks for the advice on my previous thread regarding the install of my Mira Magna dgital shower. I've just seen on the instruction manual a tiny diagram with earthing symbols on the inlet pipes and outlet pipes running from the unit. I have not done this. I did notice that the PCU flex only had live and nuetral wiring. (The pump cable had and earth wire also). Could this possibly be the reason why I'm getting nothing from the control panel?
If you think it is could you advise a good earthing point in a loft or/as I have used JG Speedfit for the pipe supply should I abridge this connection to the next available copper?
Thanks!
Thanks!
