i have the above boiler installed in my house. We are currently having problems with the micro bore piping that feeds the radiators, and it is partially blocked with sludge - this is going to be flushed soon.
However, with only some of the radiators working, the boiler keeps tripping out, the high temp sensor seems to need resetting often. Will this be because the system is not being used to its fullest, and so the recirc water is too hot?
I did see the plumber remove the temperature probe and then refit it. Im also wondering if its possible that this probe was not put back correctly.
thank you for your help.
