mix n fill
9 Oct 2005
Cardiff
I am about to sand my woodblock floor and after reading various topics on this subject am going to use mix and fill woodfiller :? for any gaps i have .
I understand that you mix the filler with sawdust from the second sand and that you fill any larger of the gaps first, what i am not sure about is the last part of the filling process when people seem to be saying that you actually cover the whole floor with the filler (almost like a screed) and then sand off when dry?
Can anybody confirm that i have understood this correctly and if not point me in the right direction.
cheers paul
Hi Paul
The mix of sanddust and filler you can see as a kind of plaster. You indeed fill the larger gaps first and then to fill all tiny gaps you 'plaster' the mix over the floor (very thinly, other wise you keep on sanding ;-) afterwards.)
Hop this makes it more clear
Thanks once again for clearing that up , will let you no how i get on and no doubt will be seeking further advice.
cheers paul
