MK Masterseal
5 Nov 2008
Hi
I have a MK masterseal single socket in my garden, this is fed directly from the CU on its own circuit with 2.5mm cable and a 16a mcb
I now need to add another socket in the garden (other side about 3m) can I connect up to my existing socket using some 2.5mm cable in plastic conduit using the masterseal conduit connectors to connect from box to box?
Insufficient protection for the cable.
This is notifiable, too.
Nothing wrong with that at all!
Tip - drill the drain hole out on the MK back box where indicated (and check the original too!).
With a 2.5mm radial you could use a 20amp MCB rather than a 16amp if you preffered.
Many Thanks,
I fitted the original socket, I rember doing the drill hole in the bottom.
