moisture resisant plasterboard
17 Feb 2011
Liverpool
have just chiselled off about four layers of tiles back to the brick in the bathroom,i am going to fix moisture resisant pb to the walls, my question is can i dot and dab the boards on or will i have to baton out and fix with screws, i have used this type of pb before. many thanks for any help :roll:
you can do either, whatever is easier for you.
A couple of points:
  • I think that dot'n'dab should not be used on solid masonry external walls.
    With d'n'd there should be a row of mechanical fastenings (screws) half way up the wall.
