Mondeo mk 3
1 Apr 2007
Durham
Hi there first post and it`s with a problem.Had the front nearside srping changed the other day as it was broken and jumped off the bottom mount,only done about ten miles since and there is an awfull noise coming from that wheel when turning right which was not there before.Took the wheel off today and it looks like the wheel bearing has a lot of play on it , will the nut on the end of the drive shaft have been removed to get the strut out or will it have been removed by loosening the clamp on the bottom of the strut. Could it be the nut has not been tightened enough (unlikely) or when i take the car back tmrw is it likely they will say it`s nothing they have done.
Also can just the wheel bearing be changed or is it a new hub job?
Thanks in advance for any helpfull replies.
