If you look on the back of the monitor it will give you the exact voltage/amps required and with which polarity.
You can then match this up in CPC, RS or as the other poster suggested, maplins. You obviously need to make sure that the connector is the same type and size.
. Thanks EOTB, on the back of the monitor it says, 12V, Amperes 3.5 and watts 4.5. What does CPC, RS and polarity mean?
PS. Had to change my user name.
